Author Topic: Mk2 power steering dropping revs!  (Read 1845 times)
Offline ashleytofield
« on: 16 June 2011, 19:33 »
Hi I recently replaced the power steering pump and now when I turn the wheel it really drops the revs, if you turn it too quick the engine stalls! The only thing i can think of is that i knakerd the hose gland when refitting so maybe it's drawing air through which is making the pump struggle?
I'm also soaking the isv as we speak, just as a precaution (I thought maybe it wasn't quick enough to deal with the extra load at idle)
Please help as I've got an Mot tomorow and really want to get it sorted! Thanks
Re: Mk2 power steering dropping revs!
« Reply #1 on: 16 June 2011, 21:04 »
Remove the cap, then turn the steering wheel lock to lock 10 tens slowly that will bleed the system.
If after that then check and see if the belt is too tight.
« Reply #2 on: 16 June 2011, 21:30 »
I have gone lock to lock loads of times, I'll give it another go though. Also I'm pretty sure the belt isn't too tight, there is a bit of play in it, how loose should it be?do you have any other ideas?
« Reply #3 on: 16 June 2011, 21:32 »
Check the idle speed, if too low that will not be helping.
« Reply #4 on: 16 June 2011, 21:39 »
It's idling at around 1000 but I have had some idling issues. It was idling to high so I had to fiddle with the idle control screw to get it idling that low.
« Reply #5 on: 16 June 2011, 21:47 »
Could be your idle valve sticking and then letting the revs drop when it releases
« Reply #6 on: 17 June 2011, 10:20 »
Right it wasnt any of those things! I'm all out of ideas and my Mot is today :s. Anybody out there that has any suggestions?
« Reply #7 on: 19 June 2011, 13:24 »
I replaced the pump yesterday just incase it was faulty and it hasn't solved the problem! Has anyone experienced this problem before? I really have run out of ideas :(
« Reply #8 on: 20 June 2011, 19:52 »
Bump
