Author Topic: 16V MK2 BOTTOM END SWAP???  (Read 1249 times)
Offline gl48lee
« on: 15 June 2011, 19:03 »
Hi im wanting to put a 2l bottom end on my mk2 16v kr engine and use the 16v kr head.
i need to know what gear box i can use as im after a cable change box???
1.is it a mk3 16v box flywheel n clutch with the mk3 gear selector onto the 2l bottom end and 16v head???
dose the bottom end have to be a 16v one or will the 8v one be ok (are they the same bottom ends with different heads) ???
thanks ppl
javascript:void(0);
Re: 16V MK2 BOTTOM END SWAP???
« Reply #1 on: 15 June 2011, 19:48 »
Yes that is correct :afro:
Nope it needs to be a 16v bottom end, I would fit a complete ABF lump given the choice.
