Author Topic: Changed my head gasket, now my heater aint working?!  (Read 1433 times)
Offline acko
Changed my head gasket on my 1.6 driver last week. Took it for a spin and it got quickly up to temp (half way on the gauge) and the heaters were blowing nice warm air for the firast time in ages! Came back and noticed I had a water leak from the plastic coolant hose manifold at the fron of the head. The one with the two coolant hoses, 3 electrical plugs that bolts to the head? Anyway i'd cracked it by having to chisel a rusty bolt off so down to the scrappy and got a new one. Swapped this over and this fixed the leak. Now the heater does not blow hot air and the temp only gets up to the firast notch on the gauge rather than half way even after an hour on the motor way!
Does this plastic manifold contain the thermostat? if so could this be causing the problem? I have the old switches which I took out of my old manifold so I could swap these over again.
As well as changing the manifold I also put some antifreeze in the coolant because up until then I had just used pure water to test for leeks etc, could this cause have caused the coolant to work more efficiently and thus not giving me any warm air? seems very unlikely!
Could it be the by-pass valves that everyone bangs on about? they are still there so may replace with copper pipe when I have the chance.
Any help appreiciated because I want my heaters back!  :angry:
Acko
Offline richandhazel
Re: Changed my head gasket, now my heater aint working?!
« Reply #1 on: 06 April 2005, 13:38 »
First thing I would try is bleeding it. You may have an airlock.
Offline ...joe
« Reply #2 on: 06 April 2005, 13:43 »
when you fill it up have your heater setting full on hot, then fill her up, leave the cap off and start the car. squeeze the bigger hoses to pump any air out and let it sit for a while getting up to temperature. then top up the expansion tank as the air is flushed out. the cooling system work on pressure so can get air locks, but if the cap is off the air works itself out.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline acko
« Reply #3 on: 06 April 2005, 18:40 »
Cool i'l give that a go, would this cause the engine temperature to stay low though? I suppose I can try it and see. cheers
