Author Topic: VAGCOM SOUTH WALES  (Read 4598 times)
Offline jamo172
VAGCOM SOUTH WALES
« on: 14 June 2011, 17:25 »
Hi is there anyone on vagcom in this area need a bit of help with a small problem??
Offline Rhyso
Re: VAGCOM SOUTH WALES
« Reply #1 on: 14 June 2011, 17:26 »
Define South Wales as that's quite a large area  :grin: :grin:
I'm in Merthyr
Offline jamo172
« Reply #2 on: 14 June 2011, 17:31 »
Sorry mate  :embarassed: i'm in ystrad mynach. i have a golf 1.8T aum it seems to be ideling a bit lumpy and now and then when she's ideling the revs will jumps up to 1000 and stright back down apat from that car runs great just would like to get this small problem sorted.
Offline Rhyso
« Reply #3 on: 14 June 2011, 21:26 »
First easy step is to clean your throttle body  :smiley:
http://www.golfgtiforum.co.uk/index.php?topic=87783.0
If that don't work give me a shout and I can pop down or you can pop up and we can see what else might be amiss  :smiley:
Offline jamo172
« Reply #4 on: 14 June 2011, 22:44 »
Will try that first Rhyso see if it helps as only happens when car is hot and idleing otherwise runs good. willlet you now.
cheers
jamie. :wink:
