Author Topic: KARCHER PROBLEM  (Read 2269 times)
Offline Live in Hope
KARCHER PROBLEM
« on: 14 June 2011, 16:43 »
HI, I have a KARCHER K6.50 which has served me well but today each time i pull the trigger it makes full pressure very quickly and then cuts pressure and starts building quickly again to full the cuts out and keeps going in this cycle.
If i turn the vario lance down and buil it up slowly it asometimes will work as normal.
Im guessing there must be some sort of pressure release valve or something, any one had an issue like this and managed to fix?
Offline Guy
Re: KARCHER PROBLEM
« Reply #1 on: 14 June 2011, 16:49 »
has it been left out in the cold?
mine did this, i never bothered but apparently you can get a replacement o ring kit off the bay
Re: KARCHER PROBLEM
« Reply #2 on: 14 June 2011, 17:00 »
HI, it has been working fine since the start of spring and does not have any water leaks :undecided:
Offline new to vw
Re: KARCHER PROBLEM
« Reply #3 on: 14 June 2011, 18:07 »
Possible air lock in the pump...????
5 door 1.8t AUM
Re: KARCHER PROBLEM
« Reply #4 on: 14 June 2011, 19:50 »
Do they suffer from this?
