Author Topic: MK5 -MOT issues.  (Read 6491 times)
Offline Phil1980
MK5 -MOT issues.
« on: 13 June 2011, 20:55 »
Right, car went into local vw dealer for an MOT today, failed on cv gaiters, apparently they were split.  They replaced one which was fine but they have now turned round and said they can't replace the other one as it is seized solid to the driveshaft.  Now they have quoted me for a new driveshaft, £280.00.  Needless to say I think they are taking me for a ride and am heading down first thing in the morning to have a look.  I have never heard of this being the case in the past, what are other people views/ideas on this?  I am now on the hunt for a specialist in my area, Norwich/Norfolk who will carry out the repair but I am a bit concerned that my car may now be completely undriveable or should it be a case that they can just reassemble what they have tried to fix so that I can take it to a specialist?.  Bloody nightmare, never had a problem with them in the past but this is the last time they will see my car.
MK5 2005 GTI, BLACK, 3 DR, 18" MONZA II, XENONS
Offline MaXXeH
  • Golf MK5 GTI
Re: MK5 -MOT issues.
« Reply #1 on: 13 June 2011, 21:15 »
seems like they are taking you for a ride mate.  I have never known one to get seized.   If it has you can get a driveshaft off ebay for £50-70
Offline Saint Steve
« Reply #2 on: 13 June 2011, 21:29 »
They arent  trying hard enough, they split the driveshaft to get the cv boot off.
it's very tight, wouldnt be seized, because it's emersed in grease it's entire live!!
 :huh:
« Last Edit: 13 June 2011, 21:51 by Saint Steve »
Offline Phil1980
« Reply #3 on: 13 June 2011, 21:33 »
Thanks for the replies, exactly my thoughts, I told them to stop working on the car and I'm going in to see what they are playing at tomorrow.  If they aree going to mess me about they can just put it back how it was and I will take it somewhere else.  Absolute stealers.  Have now found a couple of specialists that I will be ringing for quotes tomorrow.
Offline moutains
« Reply #4 on: 14 June 2011, 09:09 »
a gaiter cant sieze on a shaft its rubber cut it off cut the clips off, most garages today use a stretchy boot with a tool to slide it over the cv joint. ask your local garage to do this i got quoted £35 to do my partners honda jazz.  this way it can be done without taking the joint off which i am assuming they cant get off
« Reply #5 on: 14 June 2011, 10:26 »
Cv joints can seize on so they may be correct in what they are saying.
Offline Phil1980
« Reply #6 on: 14 June 2011, 10:36 »
Thanks for this, I just saw a video of a tool that does similar, they didn't even put it in a vice to try and get it off at the dealers, I just told them to reassemble the bits & i will take it to a specialist to repair it how you have described.  I have had my fill of dealers now trying to pull my pants down & pineapple me.
Offline maxitrol
« Reply #7 on: 14 June 2011, 19:57 »
the cv boot that we use are duro boots that you use the cone then slide the cv boot over it---think the dealers are taking the piss
Offline AlanD
  • MK5 2.0T 16v
« Reply #8 on: 15 June 2011, 11:54 »
Mine failed 2 years ago with a split CV gaiter. Just thought I'd share :D Got sorted with no dramas.
Offline Saint Steve
« Reply #9 on: 15 June 2011, 19:36 »
I think its separating the cv joint off the driveshaft, is the dealers issue.
can be tight as did mine a few months back, but with the correct tools, should be straight foward.
I managed it with a Workmate  :laugh:
