Author Topic: steering issues  (Read 1269 times)
Offline Cory
steering issues
« on: 13 June 2011, 15:01 »
so, in anticipation of my coilovers arriving, i went out yesterday, jacked the car up, and wd40 all the relevant bolts to hopefully make life easier. i drove the car last night and this morning, and im having weird play through the steering wheel, and lots of pulling to the left. it feels like the tracking is out my miles.
ive checked for play in wheels, but havent looked at ball joints, bushes etc.
anyone experienced anything similar, or advice?
cory
« Last Edit: 13 June 2011, 15:18 by Cory »
Offline sprout99
Re: steering issues
« Reply #1 on: 13 June 2011, 15:22 »
Did you get camber checked? Bad camber can make car very twitchy
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline Cory
Re: steering issues
« Reply #2 on: 13 June 2011, 15:27 »
no, havent had camber checked out. its just odd how it seems to have happened after jacking the car up. is there anything that can twist or bend?
sorry for stupid explinations/questions - im still learning
thanks
cory
Offline theclash
Re: steering issues
« Reply #3 on: 13 June 2011, 17:53 »
Where abouts did you jack the car from?
You may have bent something if you jacked in the wrong place
Offline Cory
Re: steering issues
« Reply #4 on: 13 June 2011, 22:02 »
jacked it on the sill, with the scissor jack from the boot. and then put her on axle stands at the jacking point, the cars been wax oiled and sealed, and is pretty perfect underneath. i cant imagine that i have bent anything.
im starting to think im just being a bit paranoid. i do have a snapped spring at the back, which may not be helping . . . :undecided:
Offline Ade244
Re: steering issues
« Reply #5 on: 14 June 2011, 21:29 »
Did you change a wheel? Check tyre pressures
Or If you had any work done track rod ends, wheel bearing on front, bottom ball joints, clutch etc.. its worth getting the thing laser aligned by some place that know what there doing.
Offline Cory
Re: steering issues
« Reply #6 on: 15 June 2011, 19:03 »
didnt change a wheel. or anything else. and have checked tyre pressures.
Offline wurth
Re: steering issues
« Reply #7 on: 15 June 2011, 21:59 »
If you removed the wheel, Have you torqued the wheel bolts back up ?   Why not jack the car back up and have a look, it will soon become obvious if somethings broken....
