Author Topic: Ride Height Advise - Pic  (Read 2857 times)
Offline iyrix
« on: 13 June 2011, 12:31 »
Hey All,
Im looking for a fast road setup, i've fitted some coilovers and the handling is a lot better, im wondering if it should be slightly lower at the back or all round.  Or maybe not at all.  Anyone got any good advice before i change it again.
Thanks
Graham
Golf GTI 16v
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Ride Height Advise - Pic
« Reply #1 on: 13 June 2011, 12:43 »
For driving - leave it.
For posing - slam it.
Offline justalex81
« Reply #2 on: 13 June 2011, 12:44 »
take it out for a drive. go over some speedbumps. go round some corners at speed. keep lowering by 10mm till you rub the arches or your sump jits a speed bump. then raise by 20mm  :grin: :grin: :grin:
Offline iyrix
« Reply #3 on: 13 June 2011, 12:53 »
lol - cheers guys.  This needs to be set up so it handles really well. :-)
Golf GTI 16v
« Reply #4 on: 13 June 2011, 12:55 »
Don't go too low then and make sure you get the suspension geometry set up properly once you've finished fettling with the ride height.
Offline Khare
  • The bear that khares
« Reply #5 on: 13 June 2011, 12:55 »
For good balance and driving you'll want the wishbones set level. The back go by this.
                             Reduce understeer    Reduce oversteer
Front height            lower front end         raise front end
Rear height             raise rear end           lower rear end
« Reply #6 on: 13 June 2011, 13:01 »
^^ThisĀ  :smiley:
Offline iyrix
« Reply #7 on: 13 June 2011, 13:04 »
Cheers, im going to have a play this week.  Find some "driving roads"
G.
Golf GTI 16v
Offline Len
« Reply #8 on: 13 June 2011, 13:07 »
Khare bear how do you get oversteer on a FWD car?
Its virtually impossible on normal road conditions!
www.sas.org.uk
www.the-ace.org.uk
Offline Khare
« Reply #9 on: 13 June 2011, 15:31 »
No idea, but last night going round a roundabout in the wet at normal speed I got a handful of it.
