Author Topic: Best way for cleaning the isv on an abf  (Read 2334 times)
Offline dragongreengolfgti
  • my golf gti mk3
« on: 12 June 2011, 23:03 »
Hoping you could tell me the best method for cleaning my isv on my car is it simple carb cleaner job or any other better way of doing this cheers in advance
Offline justalex81
Re: Best way for cleaning the isv on an abf
« Reply #1 on: 12 June 2011, 23:41 »
yeah man carb cleaner. leave it to soak for about half an hour
  • my golf gti mk3
« Reply #2 on: 12 June 2011, 23:59 »
ok sounds good cheers mate  :smiley:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #3 on: 12 June 2011, 23:59 »
Yup, that's all I did with mine.
Offline wrobstar21
« Reply #4 on: 13 June 2011, 08:35 »
Where's this part located & what's it look like? Would a dirty one cause a lumpy idle?
« Reply #5 on: 13 June 2011, 08:51 »
It's cylindrical in shape and located below the black plastic ignition lead tray, and yes potentially could affect idle.
Offline Khare
  • The bear that khares
« Reply #6 on: 13 June 2011, 12:08 »
I used carb cleaner. I sprayed loads of it inside and let it soak for a while, then used a toothbrush to get the crap off the inside. I had a small 12v battery nearby so I got 2 wires connected it to the correct +ve and _ve terminals and fired the ISV up for a few seconds to shift the crap inside. Again I sprayed more carb cleaner inside and repeated the process a few times and eventually clean carb fluid came out. Once dry and clean I sprayed a bit of WD40 to lube up the inside as carb cleaner leaves the ISV very dry inside.
Offline mani12354
« Reply #7 on: 13 June 2011, 12:15 »
isv????????????????:cool:
Offline Khare
« Reply #8 on: 13 June 2011, 12:18 »
Idle stabilisation valve  :smiley:
Offline mani12354
« Reply #9 on: 13 June 2011, 12:21 »
 :wink: located??
