Author Topic: no speedo or rev counter!  (Read 1541 times)
Offline l8ton
« on: 05 April 2005, 19:35 »
can anyone help! just got a y reg cab and the speedo and rev counter dont work, all the other gauges fuel and temp r fine and the lights on the dash work 2 any ideas? mot faliure! ahhh!
Offline mk1
Re: no speedo or rev counter!
« Reply #1 on: 05 April 2005, 21:27 »
Welcome l8ton.
Don't think speedo or rev counter are a MOT fail.
Speedo may be the cable and check the coil connection for the rev counter, maybe someone has had the dash out and not reconnected some stuff.
Steve.
Offline l8ton
« Reply #2 on: 05 April 2005, 21:33 »
cheers m8! thought if they dont show how fast ur going it would def fail. i tried 2 get the glocks out 2 have a look but there a pig 2 remove, someone also said it could be the relay but who knows!
Offline mk1
« Reply #3 on: 05 April 2005, 21:42 »
The speedo is cable driven, so doubt it will be a relay problem.
Steve.
Offline l8ton
« Reply #4 on: 05 April 2005, 21:54 »
thanks steve big help! ill have 2 get the clocks out then.
