Author Topic: I have a front/rear fader problem on the RNS510 .... Please HELP!!!  (Read 8945 times)
Offline am1w
Re: I have a front/rear balance problem .... Please HELP!!!
« Reply #10 on: 10 June 2011, 22:31 »
Bump again!!!!!
Any more help forthcoming, PLEASE?
Offline SteveP
« Reply #11 on: 10 June 2011, 22:46 »
Its been coded via VCDS to say it has the sound system to change the outputs into low level so they can drive the amp directly.
Offline am1w
« Reply #12 on: 10 June 2011, 22:50 »
Thanks Steve.
But can I get the F/R fader back? The fitters don't have VCDS software, of this I am sure.
Offline AGB
« Reply #13 on: 11 June 2011, 00:11 »
I thought you were talking about your wheels from your subject line...  :smiley:
MK7 Clubsport S, 981 Cayman GT4, MK7.5 GTI TCR
Offline am1w
I have amended the subject heading. Thanks.  :smiley:
Offline SteveP
« Reply #15 on: 11 June 2011, 07:37 »
Thanks Steve.
As has been said in thread, the only scenario you don't have the fader is when you have the soundpack amp so they must have changed something. If you change it back you will cause issues as you will now be driving the amp with the high level speaker outputs rather than the low level outputs that the amp requires.
Offline am1w
I realised this sort of. Now I get it. Thanks for your help. :smiley:
Offline Buck
  • Das Auto
Asker
As usual I'm late to the party  :shocked: but isn't this because your front/rear fader and EQ is all being done by your new amp, bypassing the internal controls?
Offline am1w
Asker
Better late than never.  :kiss:
I've got the solution. Coding on the RNS is scrambled possibly from day one. They did not re-code the unit either. Will be sorted during the week by the fitters when I have the new speakers fitted. All the internal controls work like R/L fader but the F/R fader facility has disappeared.
