Author Topic: Oil sensor Problem !  (Read 1710 times)
Offline brothy
« on: 10 June 2011, 18:10 »
hi, i have a golf mk4 1.8 turbo 20v, when i start the car i have a warning saying " oil sensor workshop! " then after driving shortly i warning pops up saying " low oil pressure, turn off motor! " what is the main problem?
Offline topher
  • Administrator
  • fully functioning
Re: Oil sensor Problem !
« Reply #1 on: 10 June 2011, 18:21 »
First check your oil level. If that's okay then it could either be a failing pressure sensor or more likely a blocked oil pickup pipe in the sump.
Offline brothy
« Reply #2 on: 10 June 2011, 18:31 »
Would it be werth buying a new oil pressure sensor ? if so were can i buy these from without going to the main dealer also is the sensor located on the oil pan next to the sump plug ?
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 10 June 2011, 18:35 »
that's the oil level sensor, the pressure sensor is by the oil filter
i'd have it looked at before you go throwing cash at new parts. If it is the pickup pipe blocked you risk doing some serious damage to your engine.
Offline brothy
« Reply #4 on: 10 June 2011, 18:39 »
Thanks for advice will get that checked ASAP !
« Reply #5 on: 10 June 2011, 21:46 »
Oil pick up pipe is not expensive.
