Author Topic: mk3 gti brakes  (Read 2040 times)
Offline chrismorby
mk3 gti brakes
« on: 10 June 2011, 07:27 »
Looking for new brake pads but not sure if they are 280 or 288.? whats the diffrence between them apart from 8mm! its a mk3 gti agg 96? also any recomendations?
Offline iyrix
Re: mk3 gti brakes
« Reply #1 on: 10 June 2011, 08:04 »
lol
apart from the 8mm, calipers, pads and Discs.  so not much........  :rolleyes:
To find out size meassure from top to bottom of disc.
Golf GTI 16v
Offline madmanmart
Re: mk3 gti brakes
« Reply #2 on: 10 June 2011, 08:18 »
Your car will have 288mm being a AGG 96.
Quick check, if you have a anti-rattle spring on the front of the caliper then its 288mm.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline gti gaz
Re: mk3 gti brakes
« Reply #3 on: 10 June 2011, 10:05 »
i have a 96 agg and i have 280
 Any one in cornwall lets sort more meets!!!!
Offline Dan_GTi8v
Re: mk3 gti brakes
« Reply #4 on: 10 June 2011, 11:35 »
AGG should be 288
Offline dashey
Re: mk3 gti brakes
« Reply #5 on: 10 June 2011, 12:12 »
In simple terms if you got a metal clip thing on the caliper u should see it as soon as you take the wheel off it is 288
Offline chrismorby
Re: mk3 gti brakes
« Reply #6 on: 10 June 2011, 12:17 »
yep its 288 cheers guys. next is what pads would anyone recomend? looked at EBC Green stuff and Black diamond predator pads
Offline Khare
  • The bear that khares
Re: mk3 gti brakes
« Reply #7 on: 10 June 2011, 12:23 »
280mm
288mm
Re: mk3 gti brakes
« Reply #8 on: 10 June 2011, 21:05 »
Mintex 1144 are a good choice.
Offline jonnypolish
  • t2871r needed :)
Re: mk3 gti brakes
« Reply #9 on: 10 June 2011, 22:03 »
Dont go by word of mouth, check yourself!
Made that mistake and had to send the pads back!
Mine were 288mm and its a 96 but EBC sent me the pads for 280's :(
 MK2 VR y0!
