Author Topic: Oil Pressure Sensor Potential Leak?  (Read 3670 times)
Offline Dan_GTi8v
Re: Oil Pressure Sensor Potential Leak?
« Reply #10 on: 10 June 2011, 13:35 »
As Kells said the brown one is the same as the blue one. The 2 colours relate to low (1.3 bar i think) or high (1.8 bar)
White afaik is still white but some aftermarket places replaced brown with blue, the shop should have in their computer what bar the sensor reads so worst case say u need the 1.3 bar one. You could also try and find the other one which should be somewhere near the oil filter, if that ones white you deffo need the one that isnt white  :smiley:
Offline mark-mk3gti
« Reply #11 on: 10 June 2011, 18:13 »
all sorted, was the blue one that was required, hopefully its gonna stop the oil leaks now.. fingers crossed!
thanks for all your help..
sorry didnt take pics of this, as it was straight forward...
« Reply #12 on: 10 June 2011, 21:00 »
Did you fit a new seal.
Offline mark-mk3gti
« Reply #13 on: 10 June 2011, 21:03 »
Hmm, there wasn't one now u mention it! Sh?t, i best get one tomorrow!
« Reply #14 on: 10 June 2011, 21:04 »
Should be a little o ring, if not wrap the threads in ptfe tape.
Offline mark-mk3gti
« Reply #15 on: 10 June 2011, 21:06 »
There was a small washer right at top of thread, is that where the o ring shoul be? I've probably got one that'll fit, I'll get a pic in a sec...
« Reply #16 on: 10 June 2011, 21:08 »
Was the washer copper if so that will act as a seal.
Offline mark-mk3gti
« Reply #17 on: 10 June 2011, 21:57 »
This is the old One,  but new one is the same.. don't think washer is copper... Should I put an o ring on it as well?
Cheers....
« Reply #18 on: 10 June 2011, 23:23 »
I believe the o ring sits in the groove.
Offline mark-mk3gti
« Reply #19 on: 11 June 2011, 13:46 »
I've over slept so missed tps so ptfe it will be, gonna pick some up and put some on the thread, I know gas ptfe is thicker than the water pipe one, so I'll go for water  pipe one and do 2 turns of it, should seal it ok.   Or I do have loads of rubber washers for water pipes for washers/dish washers which would fit well too... Will have a look later :)
