Author Topic: Standard door speaker rattles/fizzes when loudish  (Read 7958 times)
Offline B-chi
Re: Standard door speaker rattles/fizzes when loudish
« Reply #10 on: 09 June 2011, 19:39 »
I've had bad experiences with inphase stuff in the past. Subs, amps, components lasting under 6 months. Not sounding great compared to other brands. They are a budget brand and there is better out there for the same money. Fusion, Vibe, JBL all much better than inphase mate.
Comps = component speaker.
A component speaker set is a set of different size speakers, with a crossover which sends each particuliar speaker the optimum frequencies for it to receive.
For instance. The HU (head unit) sends out 20Hz-20kHz along down the speaker cable. Now if you tried to play 20Hz through a teeny tiny tweeter it would die. It's designed to play from around, say 5kHz. The crossover stops any frequencies under this particuliar point reaching the tweeter. Instead it send them to the other speaker in the set. A midrange for instance, whic is able to play between 60Hz & 5kHz.
Co-ax is basically a comp in one unit. You'll notice it has a little tweeter on the front of it. It'll also have a built in crossover to protect the inbuilt tweeter.
Generally the bigger the speaker the lower the frequencies it prefers to play. Hence the reason subwoofers are normally a lot bigger (10-18inchs generally) than full range speakers (normally between 8 & 4inchs).
When you buy a set of comps you'll normally have 2x bigger speakers (mids), 2 tiny speakers (tweeters), 2 crossovers (little device to split frequencies between speakers).
« Last Edit: 09 June 2011, 19:40 by B-chi »
Offline les.tansey
  • VW Golf R32 MK5 & Mercedes-Benz E320 CDI Estate
« Reply #11 on: 09 June 2011, 20:27 »
Thanks buddy, that clears a few things up a bit  :wink:
Would these be better than the in phase ones? I actually quite like the yellow for some reason :laugh:
http://www.caraudiocentre.co.uk/product_m-pioneer-ts-e1796_p-20289.htm
(As above) Golf MK3 & genuine BBS RX 16"wheels, now for sale separately - Just ask for details - Thanks, Les
Offline Len
« Reply #12 on: 10 June 2011, 09:36 »
Personally I would get Infinity speakers but may not fit your budget.
But may do, shop around.
Check the caraudiodirect link down in the Deals and Discount section as they give free delivery which will help with costs!
Components - 2 speakers one is a tweeter, the front one is in the dash and the rear is just above the door grab handle. The other is a mid/bass whish is 6.5 inch and goes in the doors.
In between the two speaker there should be a crossover, a little box with connectors. This is to seperate the  frequencies, the higher going to the tweeter and the lower to mid/bass.
www.sas.org.uk
www.the-ace.org.uk
Offline les.tansey
« Reply #13 on: 11 June 2011, 01:21 »
Riiight okay, so you know with regards to the component sets, do those tweeters go inside the dash and replace the originals in there and/or do they go in the ones next to the door grab handles in the rear doors?
Offline B-chi
« Reply #14 on: 12 June 2011, 17:57 »
Those pioneers are a good illustration of what I meant about the surround with cut outs.
Components would replace both the mid and the tweet. The beauty of after market is you can put them where you want. I have replaced the tweets and put the new ones in the standard location before. It worked well.
Any reason you picked those co-ax over some components?
Offline Len
« Reply #15 on: 13 June 2011, 13:00 »
The front set of components = tweeters go in dash. Mids go in doors
Rear set of components = tweeters go in door handle. Mids in doors.
www.sas.org.uk
www.the-ace.org.uk
Offline les.tansey
« Reply #16 on: 13 June 2011, 16:06 »
B-chi - Ermmm no reason really just thought that might be what i needed, but it seems i could be better off with component speakers... :undecided:
Len - Cheers for clearing that up
So what swould be the best to go for then co-ax or comps?
Here are two sets of comps, what would be better out of the two of them? (I would be getting two sets of these - so that all of the speakers are nice and fresh):
http://caraudiosecurity.com/shop/product/products_id/8049.html
                                          OR
http://caraudiosecurity.com/shop/product/products_id/8493.html
Oh yeah how come in the 6.5" section the woofers diameters range from 16cm - 16.5cm - 17cm... they cant all be the equivalent as 6.5"... or am i missing something?
Cheers guys :wink:
Offline Len
« Reply #17 on: 13 June 2011, 16:54 »
Components are better because they have seperate tweeters which are mounted up higher than the mids.
Its better to get the higher frequencies up nearer ear level.
www.sas.org.uk
www.the-ace.org.uk
Offline les.tansey
« Reply #18 on: 13 June 2011, 19:32 »
Ahh right, yeah that makes logical sense cheers Len.
Looks like im going for components then, so which of the above are the best, I think the kenwood ones, but... :undecided:
 :wink:
Offline B-chi
« Reply #19 on: 14 June 2011, 11:39 »
In that price range, with the supplier these
http://caraudiosecurity.com/shop/product/products_id/9119.html
Then get yourself over on talkaudio as a genesis dealer has an ex demo series 2. 2x80wrms.
That combined with those speakers could sound lovely and for under £150 as well.
