Author Topic: mileage  (Read 3525 times)
Offline AlanD
  • MK5 2.0T 16v
Re: mileage
« Reply #10 on: 10 June 2011, 10:53 »
A common fault that a few people have had including myself is a leaking coolant flange which causes you to lose coolant.
There have been a number of people having issues with the air compressor on the A/C which is expensive to fix.
Coilpacks, there has been a recall by VW
Early models GTIs had very poor DV valves, easy upgrade to a newer version.
Early models also had steering rack issues (expensive)
Due to the nature of the seat design the bolster can wear over time.
Theres a few ;)
Offline wuker
Re: mileage
« Reply #11 on: 10 June 2011, 11:42 »
I think I may have an issue with my compressor - any ideas how much it is to get it replaced?
Offline AlanD
  • MK5 2.0T 16v
Re: mileage
« Reply #12 on: 10 June 2011, 13:44 »
If you take it to a dealer (which I wouldn't suggest, Id say find a good local(ish) VAG dealer and get friendly with them) and the aircon compressor is found to be at fault they will recommend you replace that and the condenser and will want about £1400.
As I said, not cheap.
Offline wuker
Re: mileage
« Reply #13 on: 10 June 2011, 14:16 »
£1400 even at a independant garage?
That is mental
Offline AlanD
  • MK5 2.0T 16v
Re: mileage
« Reply #14 on: 10 June 2011, 14:26 »
No idea what cost would be from an indy garage, thats dealer price.
Offline Snooze
Re: mileage
« Reply #15 on: 10 June 2011, 16:10 »
Sensor in coolant bottle can go causing the warning light to go off every time you start the car. Requires a new coolant expansion vessel.
Rear wiper motor can develop fault where it goes off on it's own when you start car. Requires a new one.
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Offline Phil1980
Re: mileage
« Reply #16 on: 19 June 2011, 09:01 »
Just hit 70k miles in my 05 GTI, engine still feels sharp as the day I got it.  Coil packs, belts & water pump all changed.  Divertor valve also replaced.  Will be selling soon, what to get next though?
MK5 2005 GTI, BLACK, 3 DR, 18" MONZA II, XENONS
