Author Topic: a wierddddd sound  (Read 1731 times)
Offline navmk4gti
a wierddddd sound
« on: 08 June 2011, 19:41 »
when i reverse the car i get a loud squeel or something :embarassed:.. nothing is grinding or hiting i dont think as reverses fine just the niose well wierd like a loud metal squeel  :grin:
im thinking will changing the gearbox fluid fix it :undecided:
Offline richw911
Re: a wierddddd sound
« Reply #1 on: 08 June 2011, 19:51 »
Brake pads?
Offline navmk4gti
« Reply #2 on: 08 June 2011, 19:57 »
Brake pads?
was thinking that as they do squeek now and then.. but in reverse get load screech everytym.. the dics and pads aint that old tho about 3 months ago had new ones put in .. hope pads aint already gone  :angry:
Offline mikemk4gti
« Reply #3 on: 08 June 2011, 21:20 »
mine does that occasionally as did my last golf, when reversing pull the handbrake slightly - this stops it on mine so is obviously the rear pads.
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline navmk4gti
« Reply #4 on: 08 June 2011, 21:23 »
Yh ill do the handbrake thing .. Suprised pads gone already only been 3 munths :-@
Offline mikemk4gti
« Reply #5 on: 08 June 2011, 21:37 »
My pads were fine, just noisy.
Offline navmk4gti
« Reply #6 on: 08 June 2011, 23:33 »
did u solve it den ?
« Reply #7 on: 08 June 2011, 23:59 »
Could be a sticking caliper.
Offline mcgee9t2
« Reply #8 on: 09 June 2011, 12:54 »
could be a sticking caliper.
could be brake pads. if there pretty new and they are low then have a look at your rear axel bushes, if there worn it can give play in the axel in turn causing the pads to rub against your breaks.
mine used to squeel every so oftern going forwards but most of the time going backwards because the rear bushes were worn and had made one of my pads wear down and a small peice of metal was rubbing against the disk.
Offline navmk4gti
« Reply #9 on: 09 June 2011, 13:58 »
Raer bushes new too mate got em done with discs and pads lol my bet is on the caliper as about year half ago  when got pads dun mechanic did say rear drivers side caliper is sticking a bit but said shud be ok so I left it. How do I check if its sticking?
