Author Topic: Inner CV joint quickie  (Read 2523 times)
Offline Sam
  • Sam I am
« on: 08 June 2011, 17:37 »
Old is off and 2nd hand one is waiting to go on, but i noticed my old one doesnt have the internal circlip where as the new one does. Do you recon this was the source of the knocking, i.e if I put the circlip on my old one and packed with grease it would all be a-ok? I have 3 inner cv joints here and felt a mates the other night and all feel exactly the same with no obvious signs of brokenness.
Cheers lads  :smiley:
Offline Sam
  • Sam I am
Re: Inner CV joint quickie
« Reply #1 on: 08 June 2011, 18:42 »
No one?  :shocked:
Offline Sam
  • Sam I am
« Reply #2 on: 08 June 2011, 20:36 »
Still no one? Need to get this sorted asap
« Reply #3 on: 08 June 2011, 23:47 »
Yes fit the circlip and pack it with grease, should be fine  :smiley:
Offline haydnm0
« Reply #4 on: 09 June 2011, 01:03 »
Yes deffo fit the circlip, it won't the cause of the knock but when the steering is on a lock and the suspension extended i.e in a tight bumpy corner it stops the cv joint over extending.
Offline Diamond Hell
  • Opinions я Us
« Reply #5 on: 09 June 2011, 09:35 »
Dirty boy.
Re-pack with grease, fit circlip (why wouldn't you?!) and go again.  It'll be fine.
Offline Sam
  • Sam I am
« Reply #6 on: 09 June 2011, 10:54 »
Dirty boy.
Oh, the circlip was going on no matter what, just wondered if the joint i took off would be ok to use again or because of it not having the circlip i would need to buy a new one  :smiley: :smiley:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #7 on: 09 June 2011, 12:00 »
surely you could buy a circlip from dealers or such for very little ??
Offline Sam
  • Sam I am
« Reply #8 on: 09 June 2011, 12:43 »
Or just use on of another cv joint. Anyhow the sh!t has majorly hit the fan -  the bottom bracket on the passenger door has rotted through  :angry: good job I have just started my summer job as a fabricator again  :smiley:
Offline Sam
  • Sam I am
« Reply #9 on: 09 June 2011, 14:23 »
Oh and to ad insult to injury its still knocking when turning left and marginly when turning right
