Author Topic: Jacking point non usable  (Read 3608 times)
Offline the_stink
  • A3 140 TDI
« on: 08 June 2011, 08:50 »
so the passengerside front jacking point can really be used anymore as its had it,
is there anything i can use to plug the cracks around it? as obviously come winter that will just let everything in and the last thing i want is for rust to set in etc
so any suggestions as to whats best to use to fill / seal it  :smiley:
Offline tech1889
  • Mk2 GTI FTW !!
Re: Jacking point non usable
« Reply #1 on: 08 June 2011, 10:20 »
you got a pic so we can see how bad it is ?? cant you save up and get a welders to sort it out so you 'do' have a jacking point ??
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #2 on: 08 June 2011, 10:23 »
Coat it all with Burst. Then use some filler. If there is a hole use a bit of metal plate on the other side of the hole to cover. Then apply filler.  Bit of a bodge but works if you aren't welding.
Offline the_stink
  • A3 140 TDI
« Reply #3 on: 08 June 2011, 10:23 »
« Reply #4 on: 08 June 2011, 10:24 »
Ok Burst should read Kurust. Damn autocorrwct.
[/irony]
Offline the_stink
  • A3 140 TDI
« Reply #5 on: 08 June 2011, 10:30 »
well ill get a photo later but it is pretty ruined to be honest, ill ask my mate who is a mech and can weld seen a post else wher etha tBBT can do replacement jacking points/ pattern pannel etc might be worth looking at
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #6 on: 08 June 2011, 11:07 »
yer BBT do replacement parts might be worth a shot.. then you can cut the old one out and then all your mate need to do is literally weld new one in..
Offline the_stink
  • A3 140 TDI
« Reply #7 on: 08 June 2011, 11:20 »
that will be the easiest route i think as its been pushed up and well wont really be much use to re use, better get looking at those parts if i cna find them if not ill email BBT
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #8 on: 08 June 2011, 12:07 »
I received a battery tray repair panel from them about 20mins ago and it seems very very good quality.. will see what the fit is like though when i get chance..
Offline Reasty
  • Alpine white valver.
« Reply #9 on: 08 June 2011, 16:15 »
This is exactly what I did except I didn't get the panel from bbt I had it cut out of a dead mk2
http://www.golfgtiforum.co.uk/index.php?topic=185491.msg1733351#msg1733351
have a read of this thread there's pictures of what I had done to mine.
« Last Edit: 08 June 2011, 16:18 by Reasty »
