Author Topic: Mk3 Wheels..  (Read 3459 times)
Offline the-vicar
Mk3 Wheels..
« on: 07 June 2011, 19:00 »
Hi, I'm new to this scene i'll be perfectly honest.
I was a saxo owner.. then things went pear shaped and one thing and another.. i now own a MK3 Golf Estate (1.9TDi of course!! <-- logical choice)
after spendin only £200 ish, ive done some subtle mods, coilovers, lights, bonnet bra etc.
but now i've an issue with wheels.
first of all.. i don't understand this 7J and ET45 melachy.. it confuses the hell out of me  :undecided: .
all I no is, i want sum steelies.. that are wide.. but not too wide.. 13" ish, and will fit.
can any1 explain to me, how i simplify this into an advertising statement for some wheels?! lol
p.s. i only want 2 for the rear  :smiley:
cheers
Offline Jack3559
Re: Mk3 Wheels..
« Reply #1 on: 07 June 2011, 19:09 »
Good choice.
Am I right in thinking that you want 13" wide steels or 13" diameter steels?
Either way, weller steels make wheels to order.
Offline forsh
Re: Mk3 Wheels..
« Reply #2 on: 07 June 2011, 19:13 »
cheers
the 7 bit is inches wide
Offline forsh
Re: Mk3 Wheels..
« Reply #3 on: 07 June 2011, 19:13 »
13 inch wide is a very wide  :shocked:
Offline tweed
Re: Mk3 Wheels..
« Reply #4 on: 07 June 2011, 19:22 »
13" will never fit!
10" is asking for trouble lol
I would put a 2" band on some steels
Offline Reasty
  • Alpine white valver.
Re: Mk3 Wheels..
« Reply #5 on: 07 June 2011, 19:27 »
The j number corresponds to the width of the wheel as in the bit the tyre sits on so a 7 j wheel is 7 inches wide an 8j 8inches wide a 9j 9inches wide,you get the idea.
Et corresponds to how far the wheels sits underneath the arch so for example on a mk2  the factory Et is 35 so a wheel with ET 35 would be nicely tucked inside the wheel arch where as an ET of 15 would sit proud of the arch as in stick out slot more,as a rule the lower the ET number the further the wheel will sit proud of the wheel arch,playing with ET can make a car look more aggressive and is what is commonly done is putting a lower ET on the rear of the car to push the wheels out also known as poke
And a higher or standard ET on the front to pull the wheels under the arch which is known as tuck!
I hope this makes more sense to you now and I've not just completely confused you  :grin:
Offline Ess_Three
Re: Mk3 Wheels..
« Reply #6 on: 07 June 2011, 20:00 »
You want 13" wide rear wheels on a Golf?
A 911 GT2RS only uses 12" wide rear wheels to deploy 650 BHP...and you want wider wheels...on a FWD Golf?  :rolleyes:
..but gaining motorcycles.
Offline justalex81
Re: Mk3 Wheels..
« Reply #7 on: 07 June 2011, 23:38 »
don't underestimate those TDI's!!!! They have sh!t loads of torque and i've seen one rip up the tarmac in an asda car park once!
Offline MotorPsycho
  • I drive a 2000bhp dragster, so what ;)
Re: Mk3 Wheels..
« Reply #8 on: 08 June 2011, 08:37 »
Given he said not too wide, and 13"ish.
I'm guessing what he wants is 13" diameter steels, with decent width ~7/8".
I personally wouldn't run 13s on a mk3, far too small unless the sills are half inch off the floor.
1983 mk1, 2.0, TSR pack C head, Eaton M45 - work in progress
1990 mk2 GTD, boost, fuel, soot
16v GTi mk3; chilli red, 16" Audi Speedlines, coilies
1934 Ford Dragster, 200mph in 6 seconds.
Re: Mk3 Wheels..
« Reply #9 on: 08 June 2011, 09:21 »
15" is about the smallest wheels you want on a mk3.
« Last Edit: 07 December 2011, 21:51 by Wayne »
