Author Topic: car miss firing.  (Read 1958 times)
Offline mani12354
car miss firing.
« on: 07 June 2011, 16:46 »
hi people i got a issue (mk3 2.0gti 16v 96-97)
changed the following!
fuel filter,
fuel pressor reg,
cleaned throttle body,
cleaned the idle contral,
new map sensor,
new plugs,
new ht leads,
new cap n cog,
+ nothing comes up on vag come for errors*
hmm im lost for words  :shocked:
Offline trog_nfs
Re: car miss firing.
« Reply #1 on: 07 June 2011, 16:58 »
is it all the time or when hot/cold?
Could be temperature sensor or a vacuum leak
Offline mani12354
« Reply #2 on: 07 June 2011, 17:00 »
hot and cold lol, thing is it i checked every hose and there was nothing leaking no rips or tears there practially new
Offline trog_nfs
« Reply #3 on: 07 June 2011, 17:07 »
Ignition coil is quite common to fail
Offline mani12354
« Reply #4 on: 07 June 2011, 17:14 »
true but would that cause it to jerk backwords n forwards at 3.000 rpm
Offline tweed
« Reply #5 on: 07 June 2011, 17:28 »
My sister had a ibiza ABF and the coil went a lot on that, but often wouldn't start at all  :undecided:
Offline Sii
« Reply #6 on: 07 June 2011, 18:16 »
Please don't be offended by this but is it posible when it had the new plug leads they were put on the wrong plugs?
Just a thought.....
Offline trog_nfs
« Reply #7 on: 07 June 2011, 18:35 »
Just a thought.....
Unlikely, it would be running as rough as a badger!
not all coil failurers manifest in the same way. Coil would be my next port of call given what you've already checked and changed
Offline mani12354
« Reply #8 on: 07 June 2011, 19:24 »
LOL its running like a chainsaw now :O
Offline iyrix
« Reply #9 on: 08 June 2011, 10:08 »
Have you not changed the ECU relay?  Mine was rough as and that was it.
Golf GTI 16v
