Author Topic: Front camber adjustment  (Read 4055 times)
Offline rcsammy
« on: 05 June 2011, 17:37 »
I had the driveshafts out today and had the bolts connecting the front suspension strut to the hub out.
I have read that the bolt holes are elongated to adjust camber, but im having trouble adjusting it correctly
at the moment its got waaay too much camber, i've read of people running full camber but on mines its causing it to follow dips in the road and if i steer tight it will carry on steering rather than returning to centre.
So what method do you guys use to get it about right? and the same amount both sides
Cheers :)
this is how it is atm  :grin: looks cool but drives horrible, which is weird as i thought camber on front was supposed to aid handling/turn in
Re: Front camber adjustment
« Reply #1 on: 05 June 2011, 21:29 »
Just get a full tracking / camber check done.
Offline AudiA8Quattro
« Reply #2 on: 05 June 2011, 22:26 »
As above, tracking will need checking as well.
Offline tweed
« Reply #3 on: 06 June 2011, 17:44 »
Negative camber is bad for straight line  :laugh: It's only good in the bends. As the car rolls in the corner the tyre will become flat with the road giving more grip.
For better turn in, you want, toe out. Nothing to do with camber.
Just set one side till it looks right, then take measurements from wherever you can, and do the opposite side.
Offline leegt5
« Reply #4 on: 06 June 2011, 19:15 »
You can get the camber roughly correct..
Just a little negative camber from dead straight upright.
To get it so you don't get any uneven tyre wear your best bet it to get the tracking and camber setup properly.
Offline Jack3559
« Reply #5 on: 06 June 2011, 21:47 »
For now, it'd be safer to set the camber to default unless you want to spend out on new tyres.
You slacken the two bolts that connects the hub to the strut, then you pull on the hub until it's straight. Tighten the bolt.
Safer than that until you can get it properly checked!
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #6 on: 07 June 2011, 00:08 »
By pulling the wheel / hub out to its fullest extent you'll actually add positive camber to it,  even with it lowered (which adds negative) my wheels still kicked out at the top like a Citroën 2CV and drove crap.
Offline Jack3559
« Reply #7 on: 07 June 2011, 00:24 »
Yeah, don't pull it all the way out! Just try and straighten it a bit.
