Author Topic: Diff play  (Read 1405 times)
Offline Ade244
Diff play
« on: 05 June 2011, 12:31 »
Hi - Just picked up a 16V box from ebay  :rolleyes: really should know better but
done it now. Was hoping this one was better than the one I pulled off but...
Noticed some play if you grab the flanges there's some slight up and down and side to side play.
Is this something I can live with or should it be looked at is my question?
If I need to fix it, how simple is this job, can it be done without a full strip down?
Offline Ade244
Re: Diff play
« Reply #1 on: 05 June 2011, 19:42 »
Any thoughts? Is a bit of play OK..... or should I dig deeper before bolting it on.
Re: Diff play
« Reply #2 on: 05 June 2011, 21:11 »
Any play will be the bearings and it is not easy to replace them
Offline Ade244
Re: Diff play
« Reply #3 on: 06 June 2011, 20:34 »
Cheers I'm thinking of risking it now. I'm suspecting it wasn't rebuilt properly as the previous
owner said it had a rebuild 26K miles ago. Bearing pre load I guess, Seems on searching others have this prob
after a rebuild.
I'll get my other box sorted while this ones in the car at least the cars back on the road, been sat in a garage for a year now waiting for my mojo to come back for it...
Offline tony_ack
Re: Diff play
« Reply #4 on: 07 June 2011, 21:03 »
STOP!
To put it in perspective, I replaced my gearbox BECAUSE of the play in the diff.
Broken diff rivets may also be the culprit. They should have been replaced by bolts if it had a rebuild, but it sounds like that's turning into a big 'if'...
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
Offline Sam
  • Sam I am
Re: Diff play
« Reply #5 on: 08 June 2011, 00:17 »
Surely it is more economical to just run with it for now and if it gets worse change the box?
