Author Topic: new clutch.  (Read 1724 times)
Offline tattoomang60
  • smell the fear!!
new clutch.
« on: 04 June 2011, 21:14 »
elllo all me again how easy is it to change the clutch in a mk2 golf 16v as the one in mine is ducked :cry:
keep pushing the limits!!!
Offline mk2bal
Re: new clutch.
« Reply #1 on: 04 June 2011, 22:01 »
How long is a piece of string? All depends on how much you know/ can do.. Have a search, I'm sure I've seen someone write the job out word 4 word how to do it. I just changed my 16v gbox to 02a, and I took engine out to split it and do clutch/ seals/ master cylinder etc as I find it easier to remove the lot rather than tit about with hubs etc. Don't even have to take the wheels off. Basically if you've done a clutch/ box/ engine/ something along those lines before its not too hard
Re: new clutch.
« Reply #2 on: 04 June 2011, 23:30 »
Go for a sachs or luk kit btw.
Offline Ade244
Re: new clutch.
« Reply #3 on: 05 June 2011, 19:48 »
Easy enough, In my experience you need the car as high off the ground as poss, or use a pit or ramps.
And someone strong to wriggle it off and catch it
The box seems to jam on the diff flange also which gets you cross for a bit before you work it out
My whole engine and box is out now, although a longer job its easier to pull the whole lot out I agree.
But then you find jobs to do :grin:
  • smell the fear!!
Re: new clutch.
« Reply #4 on: 06 June 2011, 14:03 »
ello all.
made a start on it today but rain keeps stopping play poxy weather :laugh:
cheers for advice all.
  • smell the fear!!
Re: new clutch.
« Reply #5 on: 13 June 2011, 16:03 »
up date clutch in and all is well for the moment :rolleyes:
Offline Sam
  • Sam I am
Re: new clutch.
« Reply #6 on: 13 June 2011, 17:38 »
How did you do it mate? Engine out or lift her high?
  • smell the fear!!
Re: new clutch.
« Reply #7 on: 13 June 2011, 19:41 »
jacked it up as high as i could and dropped it out of the bottom :laugh:
