Author Topic: Scuttle panel warning!  (Read 4402 times)
Offline earlymk2
« on: 04 June 2011, 20:24 »
Just changed the wiper linkage on my mates Bora. Could not get the plastic scuttle panel out! The car has had a new windscreen as some point in it life, like most cars. The scuttle has ended up being glued to the windscreen by an excessive amonut of glue! If anyone gets a screen changed then if well worth a look to make sure it doesnt happen to you. It made the job a right pain. :smiley:
Offline Tazzy
Re: Scuttle panel warning!
« Reply #1 on: 04 June 2011, 23:03 »
to look at this from another angle, mine isnt glued on, but i wish it was, a slight crack in the panel anywhere, can cause it to raise and allow rain water underneath between the windscreen and run onto the ecu, causing problems for that, exactly what im having
a mint condition scuttle panel, glued onto the screen is the best option for sure to seal it in
If It Comes Off, Modify It!
Offline houston
« Reply #2 on: 05 June 2011, 14:44 »
mines glued but its the original windscreen, people sometimes glue them cos water can get in behind it and into the ecu.
only found out cos i need to grease the wiper linkage, but now i cant get at it, regular wd40 spraying to keep it going
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 05 June 2011, 14:52 »
mine has various cracks on it from getting the ECU out and feeding the pipe through for the boost gauge :grin:
Offline jonnyturbo
« Reply #4 on: 05 June 2011, 18:06 »
they are a biatch to get out lol
Offline Smiff•
« Reply #5 on: 30 September 2012, 11:17 »
I can't get my scuttle panel off.  :sad: thinking maybe it's glued? I've tried cleaning away the grime but still no joy. Any advice? If it is glued does that mean it'll never come off?
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 30 September 2012, 14:34 »
Im not sure they get glued on,i removed a mates bora one not long ago after he had given up trying,they are a mega tight fit but it will come away with enough force.
Offline cobalt6700
« Reply #7 on: 30 September 2012, 18:07 »
I took mine off to fit my boost gauge and cruise control, not only was it a bugger to get off, but i cracked my windscreen too  :cool: (before you ask, no, i wasn't using a screwdriver to pry it off)
1993 GTI 8v 5dr matt black and green - the 'sh!tball rally car'
1997 GTI 8v 3dr metalic black - the daily driver
2002 3DR 1.8T AUM silver - the new daily
1993 Jeep cherokee 4L - the weapon :D
Offline Smiff•
« Reply #8 on: 30 September 2012, 18:33 »
Cracked mine too and I still can't budge it :cry: I'm gonna have to give in and take it to the garage... and then get a new windscreen. (no I didn't use a screwdriver either).
Offline harlemex
« Reply #9 on: 02 October 2012, 13:33 »
well, i got mine off and back on without a single crack. You have to pull it as if you are trying to lift it out. Straight away from car, not upwards or downwards.  :drool: :kiss: :cool:
