Author Topic: oh b*llox is this my cv joint?  (Read 2909 times)
Offline stainesy
Re: oh b*llox is this my cv joint?
« Reply #20 on: 05 June 2011, 13:18 »
Won't get new circlip tho if one breaks getting cv off shaft
Offline AudiA8Quattro
« Reply #21 on: 05 June 2011, 16:18 »
Yes you should get a circlip as well in the kit.
Offline stainesy
« Reply #22 on: 05 June 2011, 17:05 »
Ok great so let me just confirm when I change my inner cv boot the cv joint I just take off old nackered boot. Unclip circlip and tap cv joint off the shaft.
Slide new boot over.
Cover in grease.
Push cv joint back onto shaft.
Put new circlip on then put both boot clips on.
Then driveshaft back on car.
Sound about?
« Reply #23 on: 05 June 2011, 17:16 »
Its all on the guide i posted.
Offline rcsammy
« Reply #24 on: 05 June 2011, 17:26 »
I've done mine today, mines a 1.4 but should be similar
just free up the hub by removing either the bottom or top mount, undo the large axle nut and tap out the axle
then the inner side of the driveshaft is held on with 6 torx/spline type bolts
then once off the CV joint taps off, the inner one may have a circlip, i only needed to do the outer, clean it up, put new grease in, put new boot on and re install
« Reply #25 on: 05 June 2011, 17:29 »
Similar but on gti/vr6 models a hub puller can be needed to separate the driveshaft from the hub.
Offline harlemex
« Reply #26 on: 05 June 2011, 19:44 »
It is possible to do this with the driveshaft still connected to the hub, but very fiddly when putting the circlip on. (and the boot). Best to take the shaft right off. Agreed with the hub puller being needed, and get a good one that wont break .
Offline stainesy
« Reply #27 on: 05 June 2011, 20:25 »
Great cheers peeps. So I take it its best to go vw to get boot then?
Been looking on ebay for a hub puller but han only find 4 stud ones. 5 stud one are way more expensive.
May have a look and see if we have one at work.
