Author Topic: Clutch?  (Read 1389 times)
Offline aj_golf
Clutch?
« on: 04 June 2011, 13:22 »
Ok so I've stripped my engine an replaced everything! Everything's fine exept my clutch isnt engaging when I put my foot on the pedal? It's just crunching an stalling the engine... I've tried everything, any ideas?
Much thanks
Offline Thom89
  • Looking for an "Icebreaker"
Re: Clutch?
« Reply #1 on: 04 June 2011, 13:42 »
Clutch plate in the wrong way round?!
Thom
Offline aj_golf
Re: Clutch?
« Reply #2 on: 04 June 2011, 15:03 »
Nope checked it all over. Goes into ger perfect when engine is not running! Change clutch cable as well. Got told it might be sticking?
Offline bodga
  • F reg GTI 16v
Re: Clutch?
« Reply #3 on: 04 June 2011, 15:40 »
Did  you smear some gold grease on the spline that the clutch plate slides on? also is the arm moving enough that your clutch cable is connected to coming out the bell housing? ( thinking wrong cable fitted or something  :huh:) try the old cable
Offline aj_golf
Re: Clutch?
« Reply #4 on: 04 June 2011, 17:57 »
No never greased the rod up. But it wasn't that bad! Well there was a little play but it was the same with the old one (hence why I replaced it) in theory it should work... But it ain't   :cry:
Offline Thom89
Re: Clutch?
« Reply #5 on: 04 June 2011, 19:53 »
Did you fit the clutch some time ago... could it be sticking because it been left too long without any operation? It might be worth trying to drive the car to see whether it frees its self off..
Thom
Offline aj_golf
Re: Clutch?
« Reply #6 on: 06 June 2011, 01:02 »
Yeah I'd say about month an half or two. Had problems starting the car. Could be though, would it be worth putting it in gear then starting the car?
