Author Topic: Mk 1V not sure if I have a problem or not  (Read 1824 times)
Offline SYFYHIFI
« on: 03 June 2011, 14:11 »
Had my first GTI 1.8T about four weeks.
Its a beut and I love it.
Air con doesn't seem to be working probably needs a top up what do you guys recommend on the most cost effective way to get it so it puts out cold air again?
It has also ran a bit strange for a couple of days Sunday to Wednesday on and off.
When I started it had a whining noise that tailed off after a minute or so, or if I pulled away or bipped the accelerator. This only hapenned when cold.
Thursday and today the problem hasn't been there.
Also during the same period it appeared to be running a bit rough, slightly jerky as if miss firing and there was a loss of power on acceleration.
Seems to be running ok at present BUT I assume its an intermitent fault that wil return/get worse until its there all the time.
Any ideas what this may be and potential repair costs?
« Last Edit: 03 June 2011, 14:12 by SYFYHIFI »
Offline dantheman6554
Re: Mk 1V not sure if I have a problem or not
« Reply #1 on: 03 June 2011, 14:37 »
For the aircon, get it re gassed  , around about £35 i think
The noise on start up could be the secondary air pump, or its could be coil pack failure,  their around £30 also i think
Dan
Good Old Gt Tdi 115!
Offline navmk4gti
« Reply #2 on: 03 June 2011, 20:28 »
get it on vagcom and scan it for fault codes.. cable cost 15 quid from the bay and you can download software off rosstech website  :wink:
jockgti
« Reply #3 on: 03 June 2011, 22:32 »
wheres the best place to get it regassed?
Offline new to vw
« Reply #4 on: 03 June 2011, 23:38 »
most garages can do it nowadays bud..
5 door 1.8t AUM
« Reply #5 on: 03 June 2011, 23:53 »
Anywhere apart from Kwik Fit.
Offline bobbieboy69er
  • MK4 1.8T AUM
« Reply #6 on: 04 June 2011, 01:28 »
where abouts are you?  try and find a member with vagcom until you get yourself a cable (a must)
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
Offline SYFYHIFI
« Reply #7 on: 04 June 2011, 10:54 »
I just checked through the paperwork yesterday and mine was regassed at Kwikfit May 2010!
Does that signal that I have other problems with my Aircon or that Kwikfit doesn't do it properly?
Offline SYFYHIFI
« Reply #8 on: 04 June 2011, 10:59 »
Regarding Vagcom
I'm new to all of this I understand you can get the full blown software that you put on your laptop and a usb interface to connect to the car.
I have also seen on ebay small units similar to the one in the link that have the cable and a hand held unit that displays the codes.
http://cgi.ebay.co.uk/VAG-Car-Diagnostic-Scanner-Fault-Code-reader-/160597725574?pt=UK_Diagnostic_Tools_Equipment&hash=item25645ed186
Are these any good? are the codes displayed reliable?
  • MK4 1.8T AUM
« Reply #9 on: 04 June 2011, 15:39 »
might aswel get VAGCOM mate, the code reader will give you the code however youll only have to go on your computer to look it up!
PM sent
