Author Topic: Suspension, strutt, drive shaft rubbing?  (Read 3134 times)
Offline dantheman6554
« on: 03 June 2011, 09:33 »
Just ebing lazy really, will have a look on the weekend but heres the story:
Fitted coilovers 2 weeks ago, not stupidly low, everything was fine, im getting adjustable drop links to stop the drive shaft rubbing,
But when the car hits a hump or dip in the road especially on left hand lock theres a grinding / scraping noise,  its not the sump or plastic tray,   there is some rubbage on the right hand arch, but this sounds like metal on metal!  :undecided:
Dan
Good Old Gt Tdi 115!
Offline andc1
Re: Suspension, strutt, drive shaft rubbing?
« Reply #1 on: 03 June 2011, 21:10 »
shaft hitting arb probably some cars you can get away with 40mm tops
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #2 on: 03 June 2011, 22:29 »
adjustable drop links wont really do much tbh... need an uprated arb with bigger hoops or one that goes under the driveshaft.
Offline andc1
« Reply #3 on: 03 June 2011, 22:50 »
+1
Offline heelinder
« Reply #4 on: 04 June 2011, 23:59 »
i get that same problem i just go a tad bit slower and dina go full lock  all is fine for now :drool:
« Last Edit: 05 June 2011, 00:01 by heelinder »
Offline CraigDavieBeattie
  • Golf mk5 Sport Tdi 4motion
« Reply #5 on: 05 June 2011, 01:29 »
lol I have my suspension back to standard now and what a difference the drive feels. Feels so much better than the coilovers i had (JOM). Shame its being traded in monday!
Offline golf-sib
  • Турботазик
« Reply #6 on: 05 June 2011, 13:21 »
The after market drop links are not that much short TBH, change the ARB is the best bet depending on the drop. As its the ARB where it hoops over and bolts that catches the drive shaft. The coilovers you have also make the difference in how often you catch/rub different parts, stiffer ones will catch less due to less movement such as JOMS.
You could get abit more clearance if you chop and shorten the drop links but be prepared to weld them as they are only tapped 50% and the untapped section has a wider bore meaning a new thread cannot be made.
What? You are saying a stiff firm ride is less superior to a nice bounce body rolling chassis?
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
« Reply #7 on: 06 June 2011, 10:41 »
Yep om closer inspection its the hoop on the driveshaft!  any idea on cost for one that goes underneather or a larger hoop?,  or shall i just wind the coilies up a bit until payday!?
Dan
Offline golf-sib
  • Турботазик
« Reply #8 on: 06 June 2011, 11:45 »
mk4 r32 arb has the larger hoops you want. Not sure what the price is though.
Upto you if you want to wind up it leave it ad it is. I travelled several months before I sorted my problem out and the damage done was minimum
1.8T AGU..
R135
  24
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #9 on: 06 June 2011, 12:52 »
No  :tongue:
The R32 and 4Mo bars as well as the Whiteline are under mount bars rather than hooped. Also MK1 TT iirc? So it doesn't matter how low you go they won't foul the shafts.
The Whiteline can be had from Balance motorsport for about £120
