Author Topic: help with brakes please!!  (Read 2309 times)
Offline paul7278
  • boom boom problem solved!
« on: 02 June 2011, 20:26 »
Right ive been helping my bro to try and sort the s**t  brake pedal on his m3 16v with abs. The brake pedal is really soft and has alot of travel? weve changed teh master cyclinder hoses etc and even tried aome second hand calipers along with 3 bleeds and still the same? anybody got a clue whats going on  :angry:
Offline packardjc
Re: help with brakes please!!
« Reply #1 on: 02 June 2011, 20:28 »
Get some Goodridge brake hoses, they don't expand like the rubber ones so they make the pedal stiffer.
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 02 June 2011, 20:45 »
If you pump the pedal like mad does the pedal go hard with not much travel then sink again after not pressing it for a few seconds?
Offline paul7278
« Reply #3 on: 02 June 2011, 20:56 »
no stays the same all the time!
Offline Screech16v
  • MK3 20vt AGU
« Reply #4 on: 02 June 2011, 21:05 »
Sound like you got air trapped in there still,can be a behatch sometimes ,are you doin a manual bleed with the pedal or using easy bleed/pressure bleed system?
« Reply #5 on: 02 June 2011, 21:08 »
Try bleeding with a pressure bleed kit.
Offline jon7278
« Reply #6 on: 02 June 2011, 21:09 »
Actually the pedal does go slightly harder if you pump it a few times. As Paul has said have fitted new pads all round front flexi's, master cylinder (2nd hand) and front calipers. Have bleed using an ezibleed (pressure bleeder). After bleeding them when you bleed them again air is in this system again. This is really yanking my chain now and is ruining what is an otherwise nice car.
Offline jon7278
« Reply #7 on: 02 June 2011, 21:18 »
Oh yeah forgot to mention that the NSF brake seems to get hot aswell. Have changed this caliper twice so cannot be the caliper!
Offline Screech16v
  • MK3 20vt AGU
« Reply #8 on: 02 June 2011, 21:18 »
Get your bro to pump the pedal then hold the pressure on, check all connections for leaks you may be be drawing air in through a loose union somewhere if all is good then bleed again start with the wheel furthest away from the master cylinder keep your level topped up and keep goin it will come out in the end
Offline jon7278
« Reply #9 on: 02 June 2011, 21:21 »
So use the two man method instead of pressure bleeding?
