Golf mk2
can't select reverse
Topic: can't select reverse (Read 1813 times)
cossiemark
GTI forum regular
02 June 2011, 18:24 »
Right i had one of the gear linkages brake at the weekend on my mk2 golf gti the small plastic 1.
well fitted another 1 tonight but where 1st should be i get 3rd and i get 1st when i put it in reverse any ideas??
cheers mark
Last Edit: 02 June 2011, 22:18 by cossiemark
tech1889
Serious forum addict
Mk2 GTI FTW !!
Re: can't select reverse
02 June 2011, 19:16 »
in the maintenance section i think theres a thread for setting up gear linkages
Mk4 Golf GTI anniversary and mk6 golf tdi
hennoir
03 June 2011, 20:24 »
yeah sounds like it just needs setting up again, as above think ive seen that maint guide/help...i have a similar ssue but kinda the other way round, in that can get 5th very well.....
Chris (Hennoir)
i_am_me
GTI forum regular
03 June 2011, 20:34 »
your gear selector is set wrong in the engine bay.
at the middle bottom and back of your engine bay you can see your gear linkages.
on the bar that runs straight under your car to your gear lever there is an adjuster on the end.
it has a 13mm bolt through it,if you slacken that off and turn it towards the passanger side then tighten it back up it should fix it,
you can buy a proper set up tool for it if you want or you can do it by trial and error.
<br />
If at first you don't succeed skydiving is not for you
lemski
Forum addict
16v
03 June 2011, 20:51 »
As above. Trial and error works okay. If u put it in 5th on selector and gearbox and tighten it. It should be pretty damn close
hennoir
04 June 2011, 15:49 »
Just to hijack this thread and add something, I have just been and adjusted the selector rod, just needed a couple of 13mm ring spanners and about 10-15mins.......quite easy, even having never adjusted selector before.
hopefully will help others too
Chris (Hennoir)
Golf mk2
