Author Topic: MFA accuracy  (Read 1213 times)
Offline packardjc
MFA accuracy
« on: 02 June 2011, 12:40 »
So just how accurate is the MFA? It seems to register your speed/mpg etc even when you're stationary which is annoying.
The reason I ask is that I just fitted an Ecotek valve and am being told I'm getting around 40mpg when on the same journey before I was getting about 35/37mpg (which to be honest seems high in itself).
Re: MFA accuracy
« Reply #1 on: 02 June 2011, 12:58 »
Ecotek valves are a complete waste of time and money. :rolleyes:
Offline dom
  • Back in a Mk4
Re: MFA accuracy
« Reply #2 on: 02 June 2011, 13:06 »
MFA isn't very accurate, it tends to over-read by at least 2-3mpg. Best bet is to work out actually fuel consumption based on miles covered in between fill ups.
As Wayne said an Ecotek valve is a massive waste of money :grin:
Offline packardjc
Re: MFA accuracy
« Reply #3 on: 02 June 2011, 14:09 »
Yeah there's a pretty big discussion about whether they work but I thought I'd give it a go.
Offline dom
  • Back in a Mk4
Re: MFA accuracy
« Reply #4 on: 02 June 2011, 15:22 »
Hmmm, i'm very dubious about them. It will be interesting to see if there is any difference! How much did you pay for it if you don't mind me asking?
Gavv8
Re: MFA accuracy
« Reply #5 on: 02 June 2011, 18:22 »
Mine regularly says 40mpg and i know full well it isn't.
Offline trog_nfs
Re: MFA accuracy
« Reply #6 on: 02 June 2011, 18:34 »
I've just had a look at those ecotek valves. The way they "work" (and I use the term very loosely) is by introducing an air-leak in the inlet, thus making you're car run lean. So you may gain a couple of mpg, but you risk destroying the engine, as people with 8v vauxhals have found out.
Re: MFA accuracy
« Reply #7 on: 02 June 2011, 21:31 »
Spot on :afro:
