Author Topic: Golf 1.8 Turbo GTI revs dipping  (Read 1845 times)
Offline Gabriel2202
« on: 02 June 2011, 10:46 »
Hi, I recently bought myself a mk4 golf gti t 1.8, and found that when i take it to around 4000 rpm the revs dip and it misfires, also i found when i stop it ticks over at about 900 rpm but momentarily dips to 600 rpm...
I know the previous owner had it remapped to 170bhp and put a turbo boost gauge on. Its done 75k, could it just be in need of a good service and/or cambelt change?.... any ideas what could be causing it?
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Golf 1.8 Turbo GTI revs dipping
« Reply #1 on: 02 June 2011, 11:30 »
Hello,
Could be many things, sounds like you have the AGU  or ARZ engine code if your map is at 170bhp?
Issues with higher rpm missfire could be MAF, fuel pump, or split vac line on the fuel reg, or even poor spark plug and over boosting.
As with the tick over dip this could be down to an air leak on the PCV beather system, fault maf or dirty throttle body.
You best bet is get your car booked in with some one and get the fault codes read, fuel trims checked out and a quick viaual inspection of the engine. Most good VAG specailist should do this for peanuts ££ or FOC as it will only take 10mins.
Nick
 01455 617233
Offline Gabriel2202
« Reply #2 on: 02 June 2011, 12:26 »
Ah great, thanks for your help! ive found a garage that comes recommended in leeds so will have run diagnostics, as for cambelt and service think i'm going to have to bite the bullet cus theres no history of it being done  :undecided:
thanks again!
Gabriel
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline RTechUK
« Reply #3 on: 02 June 2011, 14:13 »
thanks again!
Gabriel
Best be safe than sorry, I hope you get it sorted.. :smiley:
Nick
 01455 617233
Offline daz veedub
  • Operation 1.8t bolf
« Reply #4 on: 05 June 2011, 20:58 »
if no history defo recommend cambelt change also worth doing waterpump at same time  :smiley:
