Author Topic: Airbag light  (Read 1416 times)
Offline mattmk4
  • 1998 GTI NON turbo
Airbag light
« on: 01 June 2011, 22:43 »
Is this a known Mk4 fault that is an easy fix or anything i should be looking for?
Fault is unrelated to my starter problem!
Offline The Doc
  • E63s Estate - Vito Sport
Re: Airbag light
« Reply #1 on: 01 June 2011, 22:45 »
I'd be looking for someone with VAG-Com to scan the fault for you  :smiley:
Offline andc1
Re: Airbag light
« Reply #2 on: 01 June 2011, 22:47 »
have a play with the wires under drivers seat, mine gets caught up sometimes and light comes on, reset it with a code reader and see if it comes back on
Offline bullzeye
Re: Airbag light
« Reply #3 on: 01 June 2011, 23:00 »
when i had my mk4 1.4 and airbag light came on there was a wire that was unplugged under the seat it had like a metal  plug on the end wasnt sure it was meant to be plugged into anything untill i compared it to the other side, the light will need to be reset tho after you re connect it
cheapest mobile provider arround order a free sim with £5 credit www.giffgaff.com/orders/affiliate/s3cr3t
Re: Airbag light
« Reply #4 on: 02 June 2011, 00:08 »
Remove and clean the plugs under the seats or get it scanned.
Offline mattmk4
Re: Airbag light
« Reply #5 on: 02 June 2011, 13:32 »
how do i reset the code? can it be done by removing the battery for a while?
Offline Rhyso
Re: Airbag light
« Reply #6 on: 02 June 2011, 13:35 »
No - you can a need reader or someone with VAGCOM
