Author Topic: Broke it!  (Read 2894 times)
Offline mattmk4
  • 1998 GTI NON turbo
Broke it!
« on: 01 June 2011, 21:18 »
Thought i would have a useful evening and replace some bits i needed doing
First of all i replaced the passenger wing, front bumper and painted the bump strip as it had some marks from a towbar being parked against it (before i had it)
and while i was doing that i thought i would clean out the dreaded starter motor because of it whining
Well it didnt have a lot in it to be fair so after a clean up i stuck it back on.........Started first time with no noise and now nothing.
No clicking, just the fuel pump chucking fuel in
What could i have done? shall i just get a re-con starter motor now?
Offline richw911
Re: Broke it!
« Reply #1 on: 01 June 2011, 21:19 »
Broken wire to the starter?  :undecided:
Offline mattmk4
Re: Broke it!
« Reply #2 on: 01 June 2011, 21:21 »
it started first time i tried it after re-fitting
It will bump start too
Offline dashey
Re: Broke it!
« Reply #3 on: 01 June 2011, 21:21 »
Check the little plug thats is on the starter motor make sure its on proply
Offline richw911
Re: Broke it!
« Reply #4 on: 01 June 2011, 21:22 »
As i said check the wiring as you have disturbed it  :wink:
Offline mattmk4
Re: Broke it!
« Reply #5 on: 01 June 2011, 21:52 »
wiring is fine, just double checked it. i get a click at best.
i get the impression that the starter has jammed when the engine stopped
Re: Broke it!
« Reply #6 on: 01 June 2011, 22:04 »
Are you saying the fuel pump is running all the time.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Broke it!
« Reply #7 on: 01 June 2011, 22:09 »
Don't bump start it if you value your catalyst
Offline richw911
Re: Broke it!
« Reply #8 on: 01 June 2011, 22:11 »
+1
Offline Trispage
Re: Broke it!
« Reply #9 on: 01 June 2011, 22:13 »
Have you made sure the little single wire to the starter motor solenoid is intact. Mine was running for a month just by the two bits resting together. Worth a shot
