Right I've been battling at this for long enough, and im just about ready to throw it away and sulk.
Bear with me, I will do my best to explain clearly!
Bought some boge second hand 60mm lowering shocks/springs, got them all fitted, and the rears are fine, but the fronts are not.
When i bolt them all up I'm left with a fairly sizeable gap, between the top mount and the cap that bolts down on top of the body mounting point-no matter how much I tighten them up, it looks like the cap doesn't sit down inside the top mount far enough. Which of course means the shocks are free to rattle and clunk over every bump.
Tried with a different set of supersport 60mm shocks/springs, with a different set of top mounts, and same problem!
I know TDI's and VR's had different shocks because of the heavier engines, but I assumed mine would be the same as the GTi?
Someone must know the answer to this???
