Author Topic: valver failed mot  (Read 950 times)
Offline Misky
  • MK3 16v GTI FTW!!!
valver failed mot
« on: 01 June 2011, 15:30 »
Dont have the exact details but been told it requires 4 lots of seperate welding, 3 brake pipes, a ball joint and a wheel bearing.  I didnt think it was that bad.  :shocked:
I know it depends upon what welding is required but put that to the side what we looking at?
Im waiting for him to give me a quote as we speak.
MK3 16v GTI FTW!!!
Offline Luke1981
Re: valver failed mot
« Reply #1 on: 01 June 2011, 17:42 »
The actual parts wont cost that much to be honest. Where it gets expensive is the labour garage costs  :sad:
Most garages will charge a minimum of £50 an hour labour. My car is booked into the garage next week to get some welding done as well. Been quoted £140 to weld up two rusted drainage holes under the rear floor pan. Most of that cost will be taking the carpets up etc and the prep work.
Im going to do most of the prep work myself to get the cost down.
It will be the welding work that will cost you the most. Which parts need welding?
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline snifferdog
« Reply #2 on: 01 June 2011, 19:49 »
As above, tell them you can do the prep work yourself, makes it quite a bit cheaper.
All you have to do is take everything off or move it out of the way until they can gain clear access to the affected area!
Offline Misky
« Reply #3 on: 02 June 2011, 09:11 »
It has 2 pages full of fails.  :sad:
Im having the work costed today then I will ask if i take the labour out of it, if its still too much good bye valver hello, new loan and cooper s.
 :cry:
MK3 16v GTI FTW!!!
