Author Topic: Coolant loss  (Read 3191 times)
Offline Shady Pioneer
  • graphic designer.
Coolant loss
« on: 01 June 2011, 00:01 »
It's happened twice in about a month now, about a quarter of the coolant bottle left. What are the things I need to look for? Oil isn't white so I believe I can rule out it mixing with oil.
Offline Guy
Re: Coolant loss
« Reply #1 on: 01 June 2011, 00:09 »
a leak
  • graphic designer.
Re: Coolant loss
« Reply #2 on: 01 June 2011, 00:11 »
I had a quick look around and there are no obvious signs of a leak so this is why I ask. I've read abkjt a faulty cap?
Offline Guy
Re: Coolant loss
« Reply #3 on: 01 June 2011, 00:13 »
does you have a blue cap?
Offline MK3GTI_16Valve
Re: Coolant loss
« Reply #4 on: 01 June 2011, 00:15 »
Seal could be gone in the cap...dont think their expensive....if ur sure you dont have a leak might be worth trying...could have a slight leak and if it was dripping on a warm pipe would just evaporate off and you wouldnt see any signs of leaks under the car
Offline Guy
Re: Coolant loss
« Reply #5 on: 01 June 2011, 00:20 »
whatever you do, don't use radweld or similar to bung up the problem, this will only mask the issue temporarily and fudge up your heater matrix and water pump in the long run
i take it your coolant is still clear?
  • graphic designer.
Re: Coolant loss
« Reply #6 on: 01 June 2011, 00:38 »
Black cap ftw. Will investigate further tomorrow and will probably order a new cap from VW if needed. The coolant looks clear yes.
Re: Coolant loss
« Reply #7 on: 01 June 2011, 08:47 »
Only sure way to find out if you have a leak is to get a garage to do a pressure test.
  • graphic designer.
Re: Coolant loss
« Reply #8 on: 01 June 2011, 09:42 »
I think I've found where the leak is coming from. Will post pictures shortly to confirm.
Offline trog_nfs
Re: Coolant loss
« Reply #9 on: 01 June 2011, 10:47 »
is it from a flange?  :rolleyes:
