Author Topic: Engine Conversion Queries ;)  (Read 3756 times)
Offline Rachie.V1
Re: Engine Conversion Queries ;)
« Reply #20 on: 01 June 2011, 11:08 »
don't have an overall budget but atm i don't have alot since we just got back from modded nats and the partner went abit crazy with his cougar, lol.
it'll probably be a next month thing now, that's if the cougars clutch holds on (lovely surprises them aren't they!!) I need to get having a proper look for a 1.8t then, but what i might do is get a vr6 rip that out put that in the gti then get a 1.8t for the then empty vr6 shell... hm, i don't know.
any ideas of the best places to look for a 1.8t then? :)
« Reply #21 on: 01 June 2011, 11:18 »
Ebay etc really, however you better to get a complete donor car and then sell what you don't need afterwards.
Offline Rachie.V1
« Reply #22 on: 01 June 2011, 12:53 »
I've found a 1.8t from a mk4 golf for quite cheap!!! Just thinking if I get that now then I can get the rest of the bits and bobs I need when the Cougar decides to play nice, haha.
Offline Rachie.V1
« Reply #23 on: 01 June 2011, 13:30 »
http://cgi.ebay.co.uk/audi-A4-T-99-1-8-ENGINE-72000-MILES-GOOD-WORKING-/280687398351?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item415a45cdcf#ht_519wt_1045
would this be a good start? :/
what gear box do i have to get for a 1.8t engine? got my make at the scrappy going mental searching for cars for me too, ahah.
Offline trog_nfs
« Reply #24 on: 01 June 2011, 13:36 »
A4 is no good as a donor as the engine is the wrong way.
Offline Rachie.V1
Offline benvictors
  • bgk Tuning - coming soon!!!
« Reply #26 on: 01 June 2011, 13:48 »
Thats a non turbo 1.8 = babba!!
As Wayne said the AUQ from the skoda would be a good base, bout half the price of the AMK/BAM and at a not too shabby 180 ponies, seen the engines go for around £700
Offline benvictors
« Reply #27 on: 01 June 2011, 14:04 »
Theres an AUQ on the bay at the now, its got all ancillarys and has covered 85k, £850
You will then need a 16v pressure plate, flywheel, gearbox, hydro clutch set up, cable change gear linkage and clutch, if yrs is an early spec 8v you will also need the pedalbox from a later spec car.
AUQ loom and ecu, and, will need to send the loom off for splining into yr existing one to run factory management.
Custom downpipe, cat and exhaust system, FMIC and all its pipework, various brackets, hoses, clamps etc etc etc  :cry: :cry:
Worth it in the end tho :grin:
Offline Khare
  • The bear that khares
« Reply #29 on: 01 June 2011, 23:05 »
Ideally you want to buy a donor car with the engine still attached. That way you can see the engine running and give it a good inspection rather than taking a big gamble and possibly ending up with a smoking engine or one damaged upon removal.
