Author Topic: DIY rear wheel bearing  (Read 3129 times)
Offline jammac
« on: 31 May 2011, 16:29 »
hi
ive got a kaput rear wheel bearing judging from the racket its making. ive got 2 spare kits. is this a job i can do at home with standard tools or is it gonna have to go to a garage as they all have hydrualic pullers/ press etc whatever.
its a 91 8v gti with rear discs
cheers
ITS A TRAP!
Offline Mitching
Re: DIY rear wheel bearing
« Reply #1 on: 31 May 2011, 16:30 »
You'll need a press, although I'm sure someone on here made a DIY press though.
Offline jammac
« Reply #2 on: 31 May 2011, 16:46 »
hmmmmm just found my soggy & wet haynes manual (nice) in the garage pages i need are dry! its says to drift the bearings out and use a tube drift to fit the new ones.
ive got an aluminum drift so hopefully that should do it. oh and a scaffold pole thats a tube!
ITS A TRAP!
« Reply #3 on: 31 May 2011, 16:56 »
You can get away without a press when doing the rear ones.
Offline jammac
« Reply #4 on: 31 May 2011, 17:15 »
great thats what i wanted someone to say
ITS A TRAP!
Offline AudiA8Quattro
« Reply #5 on: 31 May 2011, 17:17 »
It is easier with a press, but can still be done fairly easy without one.
Drift out the old shells, use these to tap in the new shells.
A good tip, put the disc in the oven, and the new bearing shell in the freezer.
The new shell will virtually fall in.
Offline Andy!
  • VR6
« Reply #6 on: 31 May 2011, 18:11 »
Just take it slow and easy man, its easy enough but is also easily fecked.
« Reply #7 on: 31 May 2011, 21:43 »
Great idea :afro:
Offline wiltshirewombat
« Reply #8 on: 31 May 2011, 22:20 »
I did my 2 rear wheel bearings at the weekend, was easy and I used a couple of suitably sized sockets from the days when I had a land rover and a big hammer, just make sure the bearings go in square, otherwise they will go in cock eyed and get stuck.
Offline Mr Blue
« Reply #9 on: 31 May 2011, 22:38 »
Nice tips AudiA8.
TBH the problem is the front bearings. Rears are piss.
I would just buy new disks while you are there and tap in the new bearings to that :smiley:
