Author Topic: vr6 water temp thread lol  (Read 1957 times)
Offline tweed
« on: 30 May 2011, 18:33 »
Right vr6 sits at 70 all the time.
What makes the fans come on? Once the car is hot, oil at 90+ the vans seem to be constantly on, so the water temp will never rise above 70. the vans only come on when hot, not when it's cold. Could I have a dodgy fan switch?
Or do the fans come on from oil temp?
I'm confused now and starting to feel thick lol
Re: vr6 water temp thread lol
« Reply #1 on: 30 May 2011, 20:41 »
Fans will be controlled through the fan switch and a timer relay, water temp will bring them on and nothing to do with oil temp.
Offline GrandMstRamRod
« Reply #2 on: 30 May 2011, 21:31 »
+1 could not of put it better myself!
even if your fans are on quite alot at least its not overheating!
Offline tweed
« Reply #3 on: 31 May 2011, 16:33 »
cool! that was I thought, well I knew.
So at what temp should the fans come on? got to be hotter than 70  :undecided:
« Reply #4 on: 31 May 2011, 16:57 »
Around 85 / 90 from memory.
Offline AudiA8Quattro
« Reply #5 on: 31 May 2011, 17:14 »
I thought the fans came on when it was hotter than that?
Offline tweed
« Reply #6 on: 31 May 2011, 19:13 »
See why I am confused  :laugh: water temp always at 70 and fans are ment to come on at 85/90+  :huh:
So what should I be checking? what sends the temp to the dial?
Offline Bellend
« Reply #7 on: 31 May 2011, 20:02 »
Thermostat.
Where all my moneys went.
Offline tweed
« Reply #8 on: 01 June 2011, 10:39 »
« Reply #9 on: 01 June 2011, 10:53 »
Temp sender, nothing to do with the thermostat
However if it is running cold then you could have a air lock or thermostat problem.
