Author Topic: mk3 golf non starting  (Read 1732 times)
Offline kingsleysaywell
« on: 30 May 2011, 18:31 »
hi,
ive got a mk3 golf it will only start when it is bump started
we have tried a new battery and starter motor and still no luck
anyone got any advice?
thanks
Offline lemski
  • 16v
Re: mk3 golf non starting
« Reply #1 on: 30 May 2011, 19:01 »
Crank position sensor?
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 30 May 2011, 19:09 »
Ignition switch !
« Reply #3 on: 30 May 2011, 19:33 »
Ignition switch !
ignition switch whats that?
Offline Screech16v
  • MK3 20vt AGU
« Reply #4 on: 30 May 2011, 19:40 »
Ok, its the plastic switch that is attached to the back of your ignition barrel(where you put ya key in) these commonly fail so should imagine this should be next on your hit list, :smiley:
« Reply #5 on: 30 May 2011, 19:41 »
would it still bump if this was broken then? thanks
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 30 May 2011, 19:45 »
Yes ,its normally the cranking position inside the switch that breaks thus still giving you power to the ignition circuit(lights on the dash)but wont work the starter.
« Reply #7 on: 30 May 2011, 20:31 »
As posted, Ignition switch is a very common failure.
Offline neil1780
« Reply #8 on: 30 May 2011, 21:16 »
bridge the small red/black wire on the starter with the big main live on the starter using a piece of wire with the ignition switch in the on position (so the dash lights are on), make sure its not in gear first.
If it cranks over then your ignition switch is broke, if it doesnt crank your starters broke, simples :smiley:
V6 4MOTION
« Reply #9 on: 31 May 2011, 12:29 »
could it be spark plugs?
thanks
