Author Topic: electric window problem  (Read 1794 times)
Offline MK3GTI_16Valve
Re: electric window problem
« Reply #10 on: 02 June 2011, 19:01 »
Thought i found the easiest fix ever...see pic below...reattached the wire but neither working..:(
Brian
« Reply #11 on: 03 June 2011, 18:31 »
Quick update....
Front left window has now stopped working
Anybody have any ideas?
Offline fingerman
« Reply #12 on: 11 June 2011, 21:39 »
My O/S electric windows (front and rear) have never worked since buying my mk3 tdi a month ago so had a look today  :smiley:
The switches had always clicked but no movement, anyway took the door car off and started to remove the mechanism but couldn't as it kind of got stuck removing it - so kind of give up tried to put it back but couldn't!
Anyway, took it round to me mates who's also got a mk3 tdi and he removed the mechanism and glass (it helps when he's a mechanic!)
With that all out we tried the motor again and it worked :), so re-assembled and a bit of lube at the sides and all was good, apart from when the windows goes up it's like something is blocking it, it's a bit sensitive?
Quite happy with the results, still would like the o/s rear sorting but not as important as drivers - it was like the mechanism was stuck and just needed taking to bit and putting back together
Hopefully this is of some help?
« Reply #13 on: 12 June 2011, 14:52 »
Wiring looks ok and checked around the fuse box aswell...the two front doors started working again...could be a loose connection somewhere...rear right is clicking but not moving...will try what you were saying and take out everything and reassemble must be jammed...doesnt really explain why 3 of the 4 would stop.
