Author Topic: Rear Coilover top mount removal?  (Read 742 times)
Offline nathanpotato
« on: 30 May 2011, 16:45 »
Hi I’m having a bit of a problem with a rear coilovers top mount.
I was planning on dismantling the coilovers to give them a good clean before I fit them however on one of the coilovers, after removing the top nut the top mount just came right off easy however on the other one I can’t seem to get it off.
 It spins around but just won’t pull off any ideas. Here’s a picture of it would I need to remove that nut and if so is there a special tool I would use? Thanks
Offline vdubnut
Re: Rear Coilover top mount removal?
« Reply #1 on: 30 May 2011, 17:53 »
could you get a long socket and grind it to match the slots?  I use a long one with flats ground on to get my front coils off (used it today to change top mounts lol) Need to hold the inner shaft with allen key i got a long one from halfords with a soft handle made it a lot easier to stop the shaft spinning while removing the nut bit
« Reply #2 on: 30 May 2011, 18:06 »
Thanks for the reply I’ve only got really basic tools though so couldn’t really grind anything. The nut moves using my hand up and down to a certain point but when the other rear top mount just lifted off without removing the nut I wasn’t sure if I actually needed to remove it.
