Author Topic: Manifold & Exhaust Question  (Read 1657 times)
Offline Kent
« on: 30 May 2011, 15:31 »
Hi all, I need some advice if you dont mind.
Ive just purchased a SS Manifold and Exhaust from ebay but having trouble fitting it as they dont meet up properly.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180654724263&ssPageName=STRK:MEWNX:IT
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270737483333
Anyone know where I can get the part to match them up as im stumped.
Offline James Q
Re: Manifold & Exhaust Question
« Reply #1 on: 30 May 2011, 18:10 »
Sounds daft but was the exhaust for a 16v? i notice the mani was for an 8v? if so there as an adaptor you can get to mate them up, not sure where though?
Offline Kent
« Reply #2 on: 30 May 2011, 18:52 »
They are all for an 8v so i dont think i need a reducer.
Fitted it all up  now and its as if there is a whole pipe missing where the cat would go.
Is there a pipe i can buy or do you have to get one made up?
« Reply #3 on: 30 May 2011, 20:04 »
You will need to get a pipe made up, the manifold has lost the link pipe at some point.
Offline rob.043
« Reply #4 on: 01 June 2011, 11:52 »
Get a flexi joint, loads on ebay, to allow for some movement and help prevent a broken manifold. Add a bit of pipe to that if its not possible to get a long enough flexi.
Offline lew666
« Reply #5 on: 01 June 2011, 19:47 »
ive had this exact manifold, fitted it last weekend. you will need to weld a flexi pipe on to the flange that connects to the manifold.
Offline Kent
« Reply #6 on: 01 June 2011, 23:16 »
Cheers for the info. How much did it cost you to get done? did you do it yourself or garage?
