Author Topic: power steering problem  (Read 670 times)
Offline Luke1981
« on: 30 May 2011, 13:43 »
Just noticed my power steering intermittently loses power on corners for a few minutes after starting up  then seems to be ok after a while.
The fluid level is ok. Any ideas what could be causing this?
Thanks Luke
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline LowlifeDubber
Re: power steering problem
« Reply #1 on: 30 May 2011, 13:53 »
If the fluid is old it could be worth changing it.Also there is a fairly common problem of the belt slipping when the weather is a bit wet.
If it was me i would change the fluid,check the tension on the p/s belt or if it doesnt tlook very good just replace it.Tis a simple job.
Then it would be time to start looking at the pump.
Offline Luke1981
« Reply #2 on: 30 May 2011, 14:00 »
Thanks for the help, will have a look at the belt  :smiley:
« Reply #3 on: 30 May 2011, 20:45 »
Sounds like the belt is slipping, check and adjust the tension
