Author Topic: hard to get into gears  (Read 1135 times)
Offline sharki786
  • GOT BOOST??
« on: 30 May 2011, 11:09 »
hi all
hope u guys are having a good w4nk holiday. to the point. got a problem with gears. as you know i replaced my gbox and now the problem has started where i cant select any gears while the cars started, if i try reverse it will crunch realy bad, i replaced it with a new clutch from eurocarfarts, but funny thing is that if the car isnt started i can select any gear. could it be gear linkages or the clutch cable? also is it best to get a manual cable and are they hard to set up?
will appreciate it
thank you
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
Re: hard to get into gears
« Reply #1 on: 30 May 2011, 11:57 »
 :undecided:
*****MK4 GTI T*****
Offline tweed
« Reply #2 on: 30 May 2011, 13:00 »
sounds like clutch trouble to me. Can't say anything more than that though sorry. check cable  :huh:
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 01 June 2011, 13:05 »
right bit of an update, fitted a new cable from gsf (was genuine  :shocked: )
but still the same. fiddled with the selector and got gears then before you know it we lost them again. so just got a release bearing and plate cover. is there anyway to align the selector or do i have to buy the tool? and if so where from?
thank you
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 02 June 2011, 16:39 »
F*ckin monkeys working at eurofarts! The guy gave me a clutch kit of a mk4 2.0. Luckily took the old clutch with me, compared it with every clutch that eurofarts got out was wrong, went to andrew page and he got me the right1. I asked him about the part number euro gave and he said its for a mk4 2.0. So a valued lesson learnt, take the old part with you if possible.
Over and out.
*****MK4 GTI T*****
Offline Dan_GTi8v
« Reply #5 on: 02 June 2011, 16:50 »
is this fixed now?
I never trust ecp with anything unless I know what I need, have a part number, or have the old part with me. Everytime I've asked and had to take their word for it theyve been wrong
If the problem was the selector then you wouldnt get gears with the engine off, sounds like the clutch is sticking to me
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 02 June 2011, 18:42 »
na not yet. need to get a gasket for the drive shaft flange on gbox as its leaking. 2 fcuk ups with ecp!! im going to claim labour back as im getting charged for double labour as ecp fcuked up. whats the chances of me getting anything?
*****MK4 GTI T*****
