Author Topic: Noise following cambelt change  (Read 1682 times)
Offline Big Tone
« on: 29 May 2011, 18:32 »
 :cry:
Twice now I have noticed a noise after replacing the cambelt two days ago.
The noise coincides with the label on the outside of the best passing over the tensioner.
Only happens occasionally on cold start, car drives sweet, could this just be "newness"?
As I say, she sound fine 90% of thr time.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline Granta Gti
Re: Noise following cambelt change
« Reply #1 on: 29 May 2011, 18:38 »
And you used VW parts didnt you?
Offline Big Tone
« Reply #2 on: 29 May 2011, 18:45 »
Not the waterpump, bought the one with a brass impellor.
It is definately a rubbery/belt kinda squeak but not a squeak, if you know what I mean
Offline richw911
« Reply #3 on: 29 May 2011, 19:14 »
Did you fit a new tensioner?
Offline Ant1981
  • Feed me, prod me
« Reply #4 on: 29 May 2011, 19:14 »
I had this with the drivebelt after changing my pump and cambelt kit. Took two more drivebelts until the squeak was gone  :undecided:
'09 Kawasaki Ninja ZX-6R
Offline Dave_IOW
« Reply #5 on: 29 May 2011, 19:36 »
its not the lower cambelt cover catching on the belt is it?
mine took abit of bending around till it wasnt touching it and making a noise, sounded sorta supercharged  :grin:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Big Tone
« Reply #6 on: 29 May 2011, 19:52 »
Yup,
Only happens on cold starts in the afternoons????
Double checked torque settings and everything.
Strange, but it is definately the label!
Offline Big Tone
« Reply #7 on: 29 May 2011, 20:51 »
Should I have used any threadlocker?
Ali block so thought not, but what about a little?
« Reply #8 on: 29 May 2011, 21:09 »
Sounds like the cambelt is catching the cover also might be worth checking the tension of the belt.
Offline Big Tone
« Reply #9 on: 30 May 2011, 08:57 »
Cambelt is not catching the cover, I have ran with it removed, (only the upper obviously)
I swear it its the label on the outside of the belt. sounds perfect most of the tima
