Author Topic: weird problem anyone!!!  (Read 2197 times)
Offline vwblackmk4gti
« on: 29 May 2011, 14:15 »
Hi guys,
My mate fathers mk4 GTI has a weird problem,
Symptoms;
When starting the vehicle, the whole car vibrates and when engine speed is increased the vibration gets worse, the management light isn't on and its a 1999 T plate 1.8t. The vehicle has been in the garage for 3 days and they aint been able to figure out the problem (Back street garage NOT MAIN DEALER)
Has anyone come across this problem before,
Offline bullzeye
Re: weird problem anyone!!!
« Reply #1 on: 29 May 2011, 14:24 »
Hi guys,
Symptoms;
i was told when they engine shakes (vibrates its misfiring) has it been scanned for codes?
cheapest mobile provider arround order a free sim with £5 credit www.giffgaff.com/orders/affiliate/s3cr3t
« Reply #2 on: 29 May 2011, 14:32 »
no not yet but im going up in the morning with my diagnostic kit, i thought if its a misfire the management light will appear on the dash, but could be wrong,
Offline turbo69
  • 99 agu, k03s,007p, cai, tip,3"decat, rtec remap
« Reply #3 on: 29 May 2011, 15:04 »
could be dual mass failing ?
Offline steve113
« Reply #4 on: 29 May 2011, 16:29 »
engine light does not always come on if miss fireing
« Reply #5 on: 29 May 2011, 17:23 »
ok, will check, am i right in assuming its a agu engine and does not have coil on plug setup
Offline Rhyso
« Reply #6 on: 29 May 2011, 18:20 »
they have coilpacks on each cylinder
« Reply #7 on: 29 May 2011, 19:00 »
i thought that was only vehicle's from 2000+ and not the early ones
Offline richw911
« Reply #8 on: 29 May 2011, 19:18 »
There is no management light on an early T AGU  :wink:
They have coilpacks on each cylinder as said, my guess is the ignition amp which wont throw a code.
That or the MAF again may not throw a code  :smiley:
« Reply #9 on: 29 May 2011, 19:20 »
ok will check tomorrow thanks for the info,
