Author Topic: Dizzy knock sensors  (Read 1713 times)
Offline jmsheahan
Dizzy knock sensors
« on: 29 May 2011, 12:17 »
Having trouble with my 2E dizzy. Bought as working but only seems to have spark on cylinder 1. Are the knock sensors for a PB dizzy and 2E dizzy the same/interchangeable? I don't have the dizzy next to me so can't check.
Just want to see before I go forking out for a replacement dizzy.
Thanks
Offline danny_p
Re: Dizzy knock sensors
« Reply #1 on: 29 May 2011, 12:51 »
if it's only got soark on 1 cyl it's probaly a dizzy off a cranck sensor engine not a 2e
find the pn on the dizzy and post it up
all the VW's have gone bar 1.
Offline jmsheahan
« Reply #2 on: 29 May 2011, 13:04 »
Thanks for the reply.
I'll find out the part number. From what you've mentioned though sounds like it's from an AGG block rather than 2E. Bugger.
Offline danny_p
« Reply #3 on: 29 May 2011, 14:52 »
agg and the other engines with cranck sensors just use the dizzy as a cam position sensor for the sequential fuel injection  hence there is only 1 trigger wndow in the dizzy.   not 4 trigger windows as found in dizzys off earlyer non cranck sensor engines like 2e
Offline mr mk2
« Reply #4 on: 29 May 2011, 16:29 »
Seems I might also have this problem to look forward 2, if I rememer right I think I read that u can us the pb dizzy just gotta change the gear on the bottom of it
Offline mr mk2
« Reply #5 on: 29 May 2011, 16:34 »
Yeh diamond hell posted s link to tsr about it on my '2.0 conversion' post if this helps
Offline danny_p
« Reply #6 on: 29 May 2011, 16:45 »
you need a spacer ring as well.
easy to spin out on a lathe
Offline jmsheahan
« Reply #7 on: 29 May 2011, 18:47 »
Cheers for the info guys. Bought another dizzy now - this is definitely a 2E one! I'll sell on the AGG and PB ones.
Offline mr mk2
« Reply #8 on: 29 May 2011, 19:05 »
Is a 2E one a straight swap then? With no other mods needed?
Offline jmsheahan
« Reply #9 on: 29 May 2011, 19:13 »
Straight swap.
